My dishwasher has developed a recent problem where it stays on the wash cycle indefinitely. It does not proceed to the rinse cycle and does not shut down. I can manually drain the dishwasher by holding the correct buttons. Is it the control module or the water intake valve or do you have another suggestion.
Hi:
There was one connection of a relay I think to the controller circuit board that looked blackened and had lost the solder therefore not making a connection. A retouch of solder and bingo all is well again.
Thanks for the help.
Bill
You are welcome Bill. I'm glad you were able to fix it. Thank you for your feed back.
