My Whirlpool Quite Partner iii model GU2300XTV S2 will not exit the wash cycle. It fills with water, heats up briefly, washes, drains then repeats the sequence ad nauseam. I ran the self diagnostics and everything proceeded as the technical chart W1014280013 specified (found in the washer) including confirmation that temperature was above100 deg f. That is, all except illumination of the “CIRC” lamp which does not exist on this machine.
Any suggestions?
