bill_s
#1 Posted : Wednesday, July 22, 2009 5:40:49 PM(UTC)
bill_s
My dishwasher has developed a recent problem where it stays on the wash cycle indefinitely. It does not proceed to the rinse cycle and does not shut down. I can manually drain the dishwasher by holding the correct buttons. Is it the control module or the water intake valve or do you have another suggestion.
#2 Posted : Thursday, July 23, 2009 1:31:39 PM(UTC)
Very likely the part of the control module which operates with the water heating has gone bad. Open the control panel and inspect the control module. If there is nothing wrong then check the heating circuit.
Here are the breakdown diagrams and Replacement parts for BOSCH SHU8815 UC/12 (FD 8105-) | AppliancePartsPros.com
bill_s
#3 Posted : Thursday, July 23, 2009 7:27:47 PM(UTC)
bill_s
Hi:
There was one connection of a relay I think to the controller circuit board that looked blackened and had lost the solder therefore not making a connection. A retouch of solder and bingo all is well again.
Thanks for the help.
Bill
#4 Posted : Friday, July 24, 2009 11:44:21 AM(UTC)
You are welcome Bill. I'm glad you were able to fix it.
Thank you for your feed back.
Whirlpool Quiet Partner iii stuck in wash cycle (Dishwasher Repair)
by WaltP 4/19/2020 9:47:42 AM(UTC)
Dishwasher is stuck in wash cycle (Dishwasher Repair)
by cskoyen 2/5/2012 1:36:36 PM(UTC)
Washer Stuck in Wash Cycle (Washer Repair)
by misti5768 9/28/2011 12:09:54 PM(UTC)
Dishwasher stuck in wash cycle (Dishwasher Repair)
by JD Childs 7/3/2011 7:13:29 PM(UTC)
Roper stuck in wash cycle (Washer Repair)
by LiThiuME3 8/8/2010 2:32:54 PM(UTC)
Whirlpool Washer Stuck in Wash Cycle (Washer Repair)
by dansmith60 10/24/2009 8:18:59 AM(UTC)
Bosch DW stuck in wash cycle? (Dishwasher Repair)
by greway 4/13/2009 8:07:55 AM(UTC)
Stuck in wash cycle (Dishwasher Repair)
by Sgate 10/24/2008 5:08:33 AM(UTC)
