beefacres
#1 Posted : 17 years ago
beefacres
The dryer starts fine, then runs fine for about 5 minutes. Then it just stops
#2 Posted : 17 years ago
In order to provide the most accurate advise I need the complete model number of the dryer.
The model number you posted is not a valid model number.
beefacres
#3 Posted : 17 years ago
beefacres
Gene, Thanks for trying to help, the model number is LER6620PQO
#4 Posted : 17 years ago
The whole dryer stops or it just stops heating?
If it stops completely, what happens when you try to restart it?
Does it make any unusual noises?
beefacres
#5 Posted : 17 years ago
beefacres
The dryer runs for about 5 or 10 minutes then stops. It heats fine, but won't keep running. Sometimes it will run for most of the cycle and then sometimes it stops pretty quick. It does not make any noise. Thanks Beefacres
#6 Posted : 17 years ago
If it does not make any noises and you were able to restart it right after it stopped - I do not know what is wrong.
Maybe somebody else on the forum can help you better.
Whirlpool electric dryer m#ler4631bq1 (Dryer Repair)
by Guest 3 years ago
Whirlpool electric dryer trouble (Dryer Repair)
by sometime fixer 6 years ago
Whirlpool electric dryer heating safety issues (Dryer Repair)
by Pirate111 7 years ago
wHIRLPOOL eLECTRIC dRYER (Dryer Repair)
by jjmoore 10 years ago
Old whirlpool electric dryer won't start (Dryer Repair)
by era300 10 years ago
whirlpool electric dryer (Dryer Repair)
by ajlgap19 11 years ago
Whirlpool Electric Dryer not stopping and not heating (Dryer Repair)
by rschunk 11 years ago
Whirlpool Electric Dryer Issues (Dryer Repair)
by samedpaul 11 years ago
Whirlpool Electric Dryer No Heat (Dryer Repair)
by ahrjmrecr 11 years ago
by eisehunter 12 years ago
Whirlpool Electric Dryer - Runs- No Heat! (Dryer Repair)
by Steveorageous 12 years ago
Whirlpool Electric Dryer (Dryer Repair)
by mayork 12 years ago
Whirlpool Electric Dryer, replaced timer, will not advance (Dryer Repair)
by muttonchop 12 years ago
Whirlpool Electric Dryer not getting hot (Dryer Repair)
by jonrob65 13 years ago
Whirlpool Electric Dryer heating on Air Only (Dryer Repair)
by quigleybmd 13 years ago
