Karen Lomba
#1 Posted : Saturday, December 29, 2007 12:25:16 PM(UTC)
Karen Lomba
Push the start button the dryer runs Let the button go dryer shuts off.
Ran all the test included with the dryer all check out o'k. Replaced circuit board and dryer still will not stay on:(
Maillady1
#2 Posted : Monday, December 31, 2007 7:20:32 AM(UTC)
Maillady1
Try replacing the motor relay #3405281
Part # AP3037419
Maillady1
#3 Posted : Monday, December 31, 2007 7:23:31 AM(UTC)
Maillady1
I need info on the door pin lever (the piece that tells the dryer that the door is closed and makes the light shut off) but I cannot find my manual for the dryer.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore elite dryer (Dryer Repair)
by Donniewade 3/19/2017 9:03:17 AM(UTC)
Kenmore elite dryer got a thermal fuse (Dryer Repair)
by smb5769 7/9/2015 11:35:19 AM(UTC)
Kenmore Elite Dryer Intermittently Stops Running (Dryer Repair)
by CVilla 7/7/2015 9:30:28 AM(UTC)
Kenmore Elite Dryer - stops when start button released (Dryer Repair)
by bakchr 4/13/2015 11:10:30 AM(UTC)
Kenmore Elite Dryer will not run for more than a second...have done lots of troublesh (Dryer Repair)
by The_Wizard 11/10/2014 4:39:55 PM(UTC)
kenmore elite dryer touch pad replace (Dryer Repair)
by SoCal 8/1/2014 5:03:38 PM(UTC)
Kenmore elite dryer. No heat (Dryer Repair)
by Txbigfoot 7/14/2014 10:58:25 PM(UTC)
by Lindaslats 1/19/2014 2:50:52 PM(UTC)
Erratic touchpad test results for failing Kenmore Elite Dryer (Dryer Repair)
by gmilo2 1/13/2014 5:49:01 PM(UTC)
Kenmore Elite Dryer Getting To Hot (Dryer Repair)
by TINAO 4/10/2013 10:06:52 AM(UTC)
Kenmore elite dryer wont start (Dryer Repair)
by trueblue9 12/28/2012 1:42:56 PM(UTC)
How to troubleshoot a kenmore elite dryer (Dryer Repair)
by JamesHom 7/1/2012 10:20:25 AM(UTC)
Kenmore Elite dryer time display jumps around (Dryer Repair)
by toddc 6/24/2012 7:40:54 PM(UTC)
