I have a Whirlpool Estate Dryer Model No. TGDS840JQ0 The issue is that it does not heat. When you turn it on without any clothes inside, it heats. However, when you insert clothes, it does not heat, but continues to tumble. Recently, I have replaced the Thermal Fuse a couple of times. I have also recently replaced the Thermostat. Please advise me on what to do next.
Does your dryer have a sensor dry or automatic dry cycle?
its an automatic dry cycle
What you describe sounds like a problem with the moisture sensor. I couldn't find one on parts list generated by your model number.
