tony2300
#1 Posted : Monday, June 22, 2009 6:18:22 AM(UTC)
tony2300
Drye makes a squeeking nosie coming form the back side i think
but not all the time. I am just woundering what wheel or pully or belt to change if neccessary.
kayakcrzy
#2 Posted : Tuesday, June 23, 2009 4:19:57 AM(UTC)
kayakcrzy
tony, to get to the idler pully, and the drum rollers, you have to take the front of the drum out to do it. not a big deal, but, since you are going to take the whole product apart, it is best to replace the 2 rollers and the idler pully and the belt, and you will be good for another 7 to 10 years. vacuum it out while it is all apart. tom
tony2300
#3 Posted : Tuesday, June 23, 2009 5:04:44 AM(UTC)
tony2300
I have order the Pulley the belt and the two wheels
tony2300
#4 Posted : Tuesday, June 23, 2009 5:08:58 AM(UTC)
tony2300
this is what i order
AP4046756 (37001042) Cylinder roller notes
AP4049271 (40111201) Dryer belt notes
AP4047170 (37001144) Assm, idler lever & s notes
AP4048635 (40113601) Assy, roller bracket notes
AP4291235 (Y54414) ASSEMBLY, WHEEL & BEA
kayakcrzy
#5 Posted : Tuesday, June 23, 2009 12:08:39 PM(UTC)
kayakcrzy
That will do it. Tom ApplianceEducator.com
Maytag Dryer shutting off after 2 minutes (Dryer Repair)
by Guest 11/9/2023 4:45:11 AM(UTC)
maytag dryer MEDC200XW1 (Dryer Repair)
by patnok 9/4/2023 8:02:13 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
Maytag dryer (Mode MEDC300XW1) not starting, but runs only in Wrinkle Prevent cycle. (Dryer Repair)
by Guest 7/28/2022 6:31:22 PM(UTC)
Maytag dryer won't stop on timed dry (Dryer Repair)
by eaglemtn 11/11/2021 5:35:16 PM(UTC)
Maytag Dryer Slow to Spin after parts replacement (Dryer Repair)
by steelwindmachine 8/18/2021 5:58:15 AM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
Maytag dryer MDE9316ATA (Dryer Repair)
by Guest 5/1/2021 3:45:42 PM(UTC)
Maytag Dryer (Bravos) (Dryer Repair)
by Kap61 3/29/2021 4:03:51 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
Maytag Dryer Starts But No Heat (Dryer Repair)
by boonie785 6/1/2020 3:32:33 PM(UTC)
Maytag dryer stops early (Dryer Repair)
by J-fixtit 5/28/2020 6:59:15 PM(UTC)
Maytag dryer dont start (Dryer Repair)
by jzemer 5/16/2020 5:58:30 PM(UTC)
MAYTAG dryer loud squealing/squeaking (Dryer Repair)
by joenobodyyet 3/24/2020 1:27:25 PM(UTC)
