When I start the dryer it sounds as if there are twenty pairs of boots tumbling around inside the drum. It still heats and dries the clothes but I am afraid the drum is goinf to shoot out of the front of the machine.
Any idea what my problem is?
Thank you for any help you can provide.
Here are your parts Replacement parts for MAGIC CHEF YE225LV | AppliancePartsPros.comOften this is a rear drum support roller, Item 7 in the "Tumbler" section. Usually recommended to replace both. If you look at Item 10 in the listing there is a kit with rollers and shafts so that is what I would get unless you open it up and find one of them has an obvious problem and the other looks like new. Could also be a loose baffle inside the drum. While you have it open you might as well check other parts for wear/slop re: belt, idler wheel, front drum support, drum seals, etc. Give the unit interior a good cleaning including the blower fan. It is also a good idea to clean/check your vent system. Basically an overhaul. |
THIS FORUM IS DEAD!!!!!!! |
