trishayaya
#1 Posted : Monday, October 19, 2009 8:57:04 AM(UTC)
trishayaya
dryer makes a very loud noise while in use. almost like its falling apart. I think it may need a new belt but not sure if that could be all thats causing the problem.
sidfink43
#2 Posted : Tuesday, October 20, 2009 3:27:51 PM(UTC)
sidfink43
Hi Trish
I doubt if the belt is your problem, more likely your rollers (if you have them) or your idler assembly.
I cannot get your model to come up, and I see you are having washer problems also. These are pretty old machines and I think it is probably time to go out and get a new or good used set rather than put time and money into machines of this age.
