dwalker9943
#1 Posted : Sunday, June 21, 2009 3:22:00 PM(UTC)
dwalker9943
When I start the dryer it sounds as if there are twenty pairs of boots tumbling around inside the drum. It still heats and dries the clothes but I am afraid the drum is goinf to shoot out of the front of the machine.
Any idea what my problem is?
Thank you for any help you can provide.
#2 Posted : Monday, June 22, 2009 2:22:32 AM(UTC)
Replacement parts for MAGIC CHEF YE225LV | AppliancePartsPros.com
Often this is a rear drum support roller, Item 7 in the "Tumbler" section.
Usually recommended to replace both.
If you look at Item 10 in the listing there is a kit with rollers and shafts so that is what I would get unless you open it up and find one of them has an obvious problem and the other looks like new.
Could also be a loose baffle inside the drum.
While you have it open you might as well check other parts for wear/slop
re: belt, idler wheel, front drum support, drum seals, etc.
Give the unit interior a good cleaning including the blower fan.
It is also a good idea to clean/check your vent system.
Basically an overhaul.
Horrible noise and no spin (Washer Repair)
by wilkimtur1 7/19/2018 10:18:41 AM(UTC)
GE Refrigerator Ice/water dispenser making horrible noise (Refrigerator & Freezer Repair)
by JRJACH75 5/6/2015 6:04:01 AM(UTC)
Horrible noise, comes and goes (Refrigerator & Freezer Repair)
Belarus Rob0702 9/27/2012 4:11:01 AM(UTC)
Washer quit running during final spin cycle, now making horrible noise (Washer Repair)
by justjosh3014 7/31/2012 8:44:25 AM(UTC)
KitchenAid dishwasher makes horrible noise (Dishwasher Repair)
by howalker 7/14/2010 7:05:24 PM(UTC)
dryer makes horrible noise (Washer Repair)
by trishayaya 10/19/2009 8:57:04 AM(UTC)
GE Profile Bottom freezer horrible noise/heat (Refrigerator & Freezer Repair)
by Lois 8/6/2007 7:11:14 PM(UTC)
