The ice maker in my Frigidaire refrigerator stopped making ice. Bothe the water and ice dispenser stillwork OK. The ice maker seems to still cycle but does not receive water. The blue plastic pipe that leads from the bottom water valve to the back of the ice maker has no water in it. I disconnected it, an it is not blocked. HELP!!
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. The problem is the ice maker if this works.
