Robert Laplante
#1 Posted : Wednesday, June 10, 2009 8:24:01 AM(UTC)
Robert Laplante
The ice maker in my Frigidaire refrigerator stopped making ice. Bothe the water and ice dispenser stillwork OK. The ice maker seems to still cycle but does not receive water. The blue plastic pipe that leads from the bottom water valve to the back of the ice maker has no water in it. I disconnected it, an it is not blocked. HELP!!
woodchuckie
#2 Posted : Wednesday, June 10, 2009 8:47:18 AM(UTC)
woodchuckie
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. The problem is the ice maker if this works.
frigidaire ice maker 241642503 not working (Refrigerator & Freezer Repair)
by jesus freak 8/1/2023 3:07:31 PM(UTC)
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 1/20/2023 6:39:18 AM(UTC)
Frigidaire Ice Maker Arm won't move (Refrigerator & Freezer Repair)
by Guest 7/10/2022 6:18:09 PM(UTC)
Frigidaire ice maker not working (Refrigerator & Freezer Repair)
by lilacreality 1/4/2016 1:38:29 PM(UTC)
Frigidaire Ice maker only making huge chunks (Refrigerator & Freezer Repair)
by WAKS 10/14/2015 6:46:20 PM(UTC)
frigidaire ice maker not working (Refrigerator & Freezer Repair)
by joeyjags 3/23/2015 10:39:43 AM(UTC)
Frigidaire Ice Maker Won't Turn Off (Refrigerator & Freezer Repair)
by Fathergoose007 9/7/2014 2:15:19 PM(UTC)
Frigidaire Ice Maker--making noise/not making ice (Refrigerator & Freezer Repair)
by lak 6/23/2013 3:03:35 PM(UTC)
Frigidaire Ice maker making ice very slow. (Refrigerator & Freezer Repair)
by Mrpaul88 7/27/2012 7:59:50 AM(UTC)
Frigidaire Ice Maker (Refrigerator & Freezer Repair)
by RSP3 12/23/2011 8:46:23 AM(UTC)
No water to Frigidaire ice maker. (Refrigerator & Freezer Repair)
by Ice Master 11/22/2011 8:59:04 AM(UTC)
Frigidaire Ice maker Valve not open (Refrigerator & Freezer Repair)
by jkor 5/20/2011 1:55:01 PM(UTC)
Frigidaire ice maker control panel has no power (Refrigerator & Freezer Repair)
by F1USGP 2/20/2011 2:15:22 PM(UTC)
Frigidaire ice maker switch shut off arm won't go down to on (Refrigerator & Freezer Repair)
by lcapelis 4/9/2010 1:31:50 AM(UTC)
by luigys22 2/22/2010 6:25:14 AM(UTC)
