curtisr69
#1 Posted : Saturday, June 6, 2009 3:38:12 PM(UTC)
curtisr69
whirlpool dryer will not heat properly. The heat will stay on for a little while and then kick off. It will do this for the whole cycle. It had no heat to begin with, so I replaced the ignitor. Didnt help, turned out it was a thermal fuse. Now it has this problem. Could it be the heat selector switch or the gas valve coils?
kayakcrzy
#2 Posted : Sunday, June 7, 2009 4:55:40 AM(UTC)
kayakcrzy
If the heat stays on for a little , and shuts off, and then comes back on for a little and repeats this process, you most likely have a clogged vent. Pull the dryer away from the wall if you can, and take the vent hose off the back of the dryer, and see if it works fine. If so, you have to clean the vent tube to the outside of the home. Tom ApplianceEducator.com
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Front load dryer problem (Dryer Repair)
by Guest 4/29/2021 5:08:47 AM(UTC)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Dryer problem (Dryer Repair)
by johnh@echoetching.com 3/27/2018 12:50:30 PM(UTC)
by al kopsick 10/8/2017 11:08:40 AM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
Dryer Problem (Dryer Repair)
by clcw199 11/5/2015 9:07:48 AM(UTC)
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 10/19/2015 9:06:20 AM(UTC)
by gtravis331 4/13/2014 6:01:38 PM(UTC)
by Qzzy 3/17/2014 8:01:45 PM(UTC)
clothes dryer problem (Dryer Repair)
by jsullivan652 1/28/2014 1:20:49 AM(UTC)
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 10/22/2013 3:21:12 AM(UTC)
by Pat Ranguette 8/26/2013 5:41:29 PM(UTC)
by forenz 7/2/2013 1:34:33 PM(UTC)
by Hoovdawg3 6/8/2013 3:42:16 PM(UTC)
