buckeye55
#1 Posted : Sunday, May 31, 2009 8:20:43 AM(UTC)
buckeye55
When I tried to start my dryer this morning it wouldn't start. when I pushed the start button and turned the timer too the of position it would click like it was releasing. I took the switch out and checked it for continuity. When I pressed it, it showed it had continuity , but it does not stay engaged. Model# 11087692800
sidfink43
#2 Posted : Tuesday, June 2, 2009 4:19:35 PM(UTC)
sidfink43
Hi Buckeye
Let's start by doing a few simple tests.
1. Use your meter to make certain you have 120 volts coming into the dryer.
2. Unplug the dryer, and tape the leads from the start switch together, then plug in the dryer. If it starts you have a bad start switch. Do not do this to operate the dryer, it is only for a test.
3. Do a continuity check on each of your thermostats and thermal fuse. If one is open, replace it.
4. Do a continuity test on your door switch. Check that you have continuity when the switch is engaged.
Let us know what you find out.
Good luck.
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
GE Dryer wont start (Dryer Repair)
by bob35614 2/13/2017 4:21:03 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
maytag legacy dryer wont start (Dryer Repair)
by kennypkay 11/15/2015 2:02:45 PM(UTC)
Admiral Dryer wont start (Dryer Repair)
by chargitt 8/24/2015 1:25:34 PM(UTC)
kenmore dryer wont start (Dryer Repair)
by coindog1 7/26/2015 12:33:16 PM(UTC)
by antoine123 6/10/2015 5:23:52 PM(UTC)
dryer contol lock is locked -dryer wont start (Dryer Repair)
by k62254 5/29/2015 1:10:18 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Whirlpool dryer wont start (Dryer Repair)
by laundry1 1/20/2015 11:46:37 AM(UTC)
dryer wont start (Washer Repair)
by rangerleader63@gmail.com 9/4/2014 7:56:01 AM(UTC)
by mich01 9/1/2014 4:17:03 PM(UTC)
maytag dryer wont start (Dryer Repair)
by clavin29 3/1/2014 7:22:21 AM(UTC)
by cnrimgr1 2/17/2014 12:27:23 PM(UTC)
