JZWEIGLE
#1 Posted : Thursday, May 28, 2009 2:57:10 PM(UTC)
JZWEIGLE
Water Goes Into Tumbler,doesnt Seem To Complete Fill Cycle Then Stops. If You Tilt Machine Towards You Water Does Enter Tumbler But As Soon As You Set Machine Back Down It Stops, Is It The Pump? It Is The Original Pump. It Also Does No Cycling At All,code El Comes Up Along With Fl Thank-you does anyone know can someone help almost 24hours old
sidfink43
#2 Posted : Friday, May 29, 2009 11:49:59 AM(UTC)
sidfink43
These are great machines when they work. When they do not, well, you know already.
Here is a sevice manual (whirlpool makes kenmore appliances whose model number starts with 110)
http://adcxns1.whirlpool...4632a4/$FILE/8178010.pdf
Take a look and see if that helps. The most likely culprit will be your control board (of course, its like almost the most expensive)
Good luck and let us know what you find out.
Kenmore Calypso Dryer (Dryer Repair)
by sunnywene 4/1/2011 6:21:54 PM(UTC)
Kenmore Calypso Dryer (Washer Repair)
by sunnywene 3/31/2011 8:04:35 AM(UTC)
Fancy Kenmore Calypso Dryer--No Heat (Dryer Repair)
by steve7 8/7/2010 10:45:36 PM(UTC)
kenmore calypso stuck in rinse cycle (Washer Repair)
by wesconson 5/25/2010 10:00:06 AM(UTC)
kenmore calypso washer (Washer Repair)
by bettyyester 6/20/2009 6:09:02 AM(UTC)
Kenmore Calypso problem I can't figure out (Washer Repair)
by arcticcatmatt 5/20/2009 7:25:37 PM(UTC)
kenmore calypso (Washer Repair)
by j hatfield 5/7/2009 12:28:00 PM(UTC)
Kenmore Calypso Stains (Washer Repair)
by edcard 11/18/2008 10:59:32 AM(UTC)
