Dryer running but no heat. Looking for right heating element & thermal fuse, but not finding on website yet. -- Planning to check for lint/exhaust clogs then heating element, thermal fuse, wires. Is that correct procedure? [Just repaired both automobiles & washer--now it's the dryer. No budget left; hoping to fix this myself if possible. Thanks. --Steve H. in Jacksonville]
Here is the tech sheet for this unit http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208541083.pdfAlthough the parts do not come up when searching AppliancPartsPros they will be available from them. Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Be careful as 240 volts is lethal !!! Try running the diagnostics. |
THIS FORUM IS DEAD!!!!!!! |
