steve7
#1 Posted : Saturday, August 7, 2010 10:45:36 PM(UTC)
steve7
Dryer running but no heat. Looking for right heating element & thermal fuse, but not finding on website yet. -- Planning to check for lint/exhaust clogs then heating element, thermal fuse, wires. Is that correct procedure? [Just repaired both automobiles & washer--now it's the dryer. No budget left; hoping to fix this myself if possible. Thanks. --Steve H. in Jacksonville]
#2 Posted : Sunday, August 8, 2010 3:49:13 AM(UTC)
Here is the tech sheet for this unit
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208541083.pdf
Although the parts do not come up when searching AppliancPartsPros they will be available from them.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Try running the diagnostics.
