bettyyester
#1 Posted : Saturday, June 20, 2009 6:09:02 AM(UTC)
bettyyester
I have a Kenmore Calypso Washer It doesn't work at all I unplugged and tried it in an outlet I knew was working and nothing happened Is there some type of reset button It was repaired 5 times under warranty several years ago so I know how expensive everything is If I can't fix it I will have to junk it The repair charges (which were covered under warranty) would have been about twice as much as the washer cost
#2 Posted : Sunday, June 21, 2009 1:18:03 AM(UTC)
This should help
https://secured.whirlpoo...4632a4/$FILE/8178010.pdf
I am assuming the unit is totally dead.
You will need a meter to check for power in the unit.
Could be the unit's line filter is blown.
dwb
#3 Posted : Tuesday, December 1, 2009 8:41:12 PM(UTC)
dwb
Originally Posted by: denman Go to Quoted Post
This should help
hi, what did the problem turn out to be???
