Tazlyne4u
#1 Posted : Tuesday, May 5, 2009 3:58:40 PM(UTC)
Tazlyne4u
Dryer just stopped heating. No warning.
sidfink43
#2 Posted : Wednesday, May 6, 2009 8:11:43 AM(UTC)
sidfink43
Well, first you need to check and make certain you are still getting 240 volts to the machine. Sometimes the breaker will partially trip and send enough power to operate the machine but not enough to cause the heating coils to come one.
If this is not the problem, and likely it is not, then you need to open up the machine and do a continuity test on the thermostats and safety fuses. Be sure and disconnect the power to the machine when doing this.
If you find this is the problem, take the opportunity to also thoroughly clean out the venting system. Restricted air flow is the single largest cause for a thermostat/fuse failure.
Good luck, and post the results. If you do not find the problem let us know also.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
