We replaced the water pump on my washer. Now when the washer goes to spin out it makes a loud clicking noise. When you look at it turning the spin clutch is slipping. How do you fix this?
Can you expand a little on what you mean by the spin clutch is slipping? Try to describe exactly what is happening when you operate the machine with the front cover off so you are looking at the mechanism.
Assuming this problem did not occur before you changed the pump, I would remove your new pump, turn it by hand to see if the problem is in the new pump and then place it back on the machine, making sure it is on correctly. Then try the machine and see what happens.
Good luck, and post your results.
Thanks for you reply to my problem. When the washer goes into the spin cycle, the two piece white plastic clutch nut at the end of the shaft is jumping over it's self. The tub will not turn and it mades a very loud clicking noise. Thanks, D.O.
I am still having trouble visualizing your problem, (not unusual in this type of forum) but here is the service manual for your model. Look at it and see if you can locate the source of your problem there. http://www.servicematters.com/m...ibrary/docs/16022937.pdfGood luck, and continue to post with questions if you have any.
