dowens59@bellsouth.net
#1 Posted : Tuesday, April 28, 2009 5:28:51 PM(UTC)
We replaced the water pump on my washer. Now when the washer goes to spin out it makes a loud clicking noise. When you look at it turning the spin clutch is slipping. How do you fix this?
sidfink43
#2 Posted : Thursday, April 30, 2009 3:18:14 PM(UTC)
sidfink43
Can you expand a little on what you mean by the spin clutch is slipping? Try to describe exactly what is happening when you operate the machine with the front cover off so you are looking at the mechanism.
Assuming this problem did not occur before you changed the pump, I would remove your new pump, turn it by hand to see if the problem is in the new pump and then place it back on the machine, making sure it is on correctly. Then try the machine and see what happens.
Good luck, and post your results.
#3 Posted : Thursday, April 30, 2009 6:24:39 PM(UTC)
Thanks for you reply to my problem. When the washer goes into the spin cycle, the two piece white plastic clutch nut at the end of the shaft is jumping over it's self. The tub will not turn and it mades a very loud clicking noise. Thanks, D.O.
sidfink43
#4 Posted : Friday, May 1, 2009 8:09:17 AM(UTC)
sidfink43
I am still having trouble visualizing your problem, (not unusual in this type of forum) but here is the service manual for your model. Look at it and see if you can locate the source of your problem there.
http://www.servicematters.com/m...ibrary/docs/16022937.pdf
Good luck, and continue to post with questions if you have any.
GE washer Problems w/ Agitation GCWN3000M1WS (Washer Repair)
by ps33 12/19/2020 4:19:13 PM(UTC)
Kenmore VMW 22352 Washer Problems (Washer Repair)
by Papa_omero 3/11/2019 5:25:53 PM(UTC)
Whirlpool Duet Sport Washer problems (Washer Repair)
by bdmbluegrass 1/11/2017 11:54:22 AM(UTC)
washer problems (Washer Repair)
by porterbridges 1/18/2015 10:53:23 AM(UTC)
by Revelation320 9/4/2013 4:41:04 PM(UTC)
Commerical Washer Problems (Washer Repair)
by sherryash 12/18/2012 3:11:25 PM(UTC)
by mariela 10/24/2012 7:44:31 PM(UTC)
Bosch Dishwasher problems (Dishwasher Repair)
by Manuel Arce 9/15/2012 9:14:41 AM(UTC)
Whirlpool dishwasher Problems (Dishwasher Repair)
by captbud 8/1/2012 10:21:44 AM(UTC)
by malon66 6/21/2012 6:17:18 PM(UTC)
WP Ultimate Care 2 washer problems...new timer didn't fix (Washer Repair)
by HunterTinsley 4/6/2012 6:11:49 PM(UTC)
Whirlpool Washer Problems (Washer Repair)
by GK12 3/4/2012 1:28:37 PM(UTC)
LG Dishwasher problems HELP! (Dishwasher Repair)
by djmcheme 11/19/2011 11:05:29 AM(UTC)
Intermittent washer problems (Washer Repair)
by rscha787 10/12/2011 5:56:35 PM(UTC)
by jamesnl 10/9/2011 2:13:43 PM(UTC)
