gwp510
#1 Posted : Monday, April 27, 2009 7:56:15 AM(UTC)
gwp510
1 year ago the dryer wasn't heating, the repair guy replaced the gas valve coilbut I don't know which one the main or the secondary. The dryer has been working fine. On Sturday I had to move the dryer so I unplugged it ,disconnected the vent and disconnected the gas supply. Upon completion of my project I moved the dryer back into place, connected the gas, connected the vent and plugged it back in. To my surprise the dryer will not heat. I openned the front and turned it on. I did not notice the ignitor glowing at any time, so I imagine the gas valve won't open. What is my problem? The ignitor, the coils or the tube sensor. I did nothing but move the dryer about 5 feet and then moved it back. What happened?
#2 Posted : Monday, April 27, 2009 10:47:52 AM(UTC)
The igniter coil is very gentle and easy to damage. The first thing I would do in such case is check the igniter. Unplug the igniter wire harness plug and check it for continuity.
Here are the breakdown diagrams and Replacement parts for MAYTAG MDG7600AWW | AppliancePartsPros.com
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
