I have power to my unit and have reset the circut.(interior light and lock work) There is no display. Is it necessary to replace entire panel, or is there a part for display? 3 yrs. old
Thanks, Andy
If you have 120 volts going to the control/clock then you will have to replace the entire microcomputer.
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
HI, I need help with wiring for GE Oven model # JBP30BA4AD, electronic control wiring (TO8C). I have a new replacement part but the wiring is not exactly the same. How do I proceed?
I replaced my old controller with a TO8-2K controller using the wiring diagrm referenced on Michael's question. It seems to be working until we try to use the oven. The controller will read the temperature for a short while then give an F4 error, and the oven does not heat up at all. Did I wire it up wrong?
