andye
#1 Posted : 18 years ago
andye
I have power to my unit and have reset the circut.(interior light and lock work) There is no display. Is it necessary to replace entire panel, or is there a part for display? 3 yrs. old
Thanks, Andy
ApplianceJunk
#2 Posted : 18 years ago
ApplianceJunk
If you have 120 volts going to the control/clock then you will have to replace the entire microcomputer.
Admin / APP Team
#3 Posted : 18 years ago
Admin / APP Team
Rank: Administration
Good answer, ApplianceJunk.
Andy, if you need/decide to replace the control, here is the right one for your model - Part Details - WHIRLPOOL Electronic clock control board, part number: AP3595759
Michael
#4 Posted : 18 years ago
Michael
HI,
I need help with wiring for GE Oven model # JBP30BA4AD, electronic control wiring (TO8C). I have a new replacement part but the wiring is not exactly the same. How do I proceed?
john.richard
#5 Posted : 15 years ago
john.richard
I replaced my old controller with a TO8-2K controller using the wiring diagrm referenced on Michael's question. It seems to be working until we try to use the oven. The controller will read the temperature for a short while then give an F4 error, and the oven does not heat up at all. Did I wire it up wrong?
Trying To Find Electronic Oven Control For My (Oven Repair (including Ranges and Cooktops))
by sfmiller1954 13 years ago
Electronic Oven controls (Oven Repair (including Ranges and Cooktops))
by dsarabia25 14 years ago
unglued electronic oven control (Oven Repair (including Ranges and Cooktops))
by jtrigdon 14 years ago
electronic oven control installation (Oven Repair (including Ranges and Cooktops))
by blossom12562 14 years ago
Electronic Oven Control Blank (Oven Repair (including Ranges and Cooktops))
by MMCD 14 years ago
by flyfishn4u2 14 years ago
Electronic oven control (Oven Repair (including Ranges and Cooktops))
by theglen 14 years ago
Electronic Oven Control for a GE (Oven Repair (including Ranges and Cooktops))
by dixiedog 15 years ago
Electronic Oven control (Oven Repair (including Ranges and Cooktops))
by jkmccull 15 years ago
I think I have a bad electronic oven control ?? (Oven Repair (including Ranges and Cooktops))
by tinner 15 years ago
No Display on Electronic Oven Controller/Clock (Oven Repair (including Ranges and Cooktops))
by who_dat 15 years ago
by john leonhart 16 years ago
Electronic oven control assembly I did something wrong... (Oven Repair (including Ranges and Cooktops))
by Gary Hagen 16 years ago
Electronic Oven Control Assembly - Ribbon (Oven Repair (including Ranges and Cooktops))
by papa5032 16 years ago
Instructions to Install Electronic Oven Control (Oven Repair (including Ranges and Cooktops))
by gelefante 17 years ago
