jay05
#1 Posted : Tuesday, April 14, 2009 6:42:09 PM(UTC)
jay05
Have this fridge. Since about a year after new, it has been leaking from the freezer into the fridge. When I look in the freezer, the drain at the back is frozen over. The water then runs down into the fridge and to the botton where the crispers are, and it freezes there as well. The fridge and the freezer are not set that high so I'm not sure what to do about this. When I defrost the drain hole, it lasts a couple weeks or so, then starts all over again. I read a post about another person who sounds like they had the same/ similar problem, but I did not see a response to the problem. Can anyone help?? Thank you
woodchuckie
#2 Posted : Tuesday, April 14, 2009 7:42:22 PM(UTC)
woodchuckie
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Bottom Freezer Leaking Water (Refrigerator & Freezer Repair)
by fscel 2/13/2024 11:22:53 AM(UTC)
Freezer leaking, ice build up (Refrigerator & Freezer Repair)
by robink2306 11/21/2022 8:47:52 PM(UTC)
Maytag Freezer leaking into Fridge (Refrigerator & Freezer Repair)
by HKeyzer 5/15/2017 8:00:10 AM(UTC)
Kenmore Side by Side Freezer Leaking (Refrigerator & Freezer Repair)
by rkirkwo1 10/3/2016 10:27:43 AM(UTC)
Freezer leaking water in dispenser tray (Refrigerator & Freezer Repair)
by Robak 7/3/2014 11:11:02 AM(UTC)
LG bottom freezer leaking (Refrigerator & Freezer Repair)
by Molly63 3/16/2014 6:44:33 AM(UTC)
Freezer leaking water from ceiling vent (Refrigerator & Freezer Repair)
by dhog 4/24/2013 7:31:52 PM(UTC)
freezer leaking inside (Refrigerator & Freezer Repair)
by smiebd 1/26/2012 8:39:51 AM(UTC)
Freezer leaking water in refrig (Refrigerator & Freezer Repair)
by Waza 11/28/2011 7:01:41 PM(UTC)
Maytag Freezer Leaking Water From Ice Maker (Refrigerator & Freezer Repair)
by PASADENASBUICK 10/8/2010 6:59:32 AM(UTC)
Freezer leaking from freezer side out to floor (Refrigerator & Freezer Repair)
by ladyred1101 9/12/2010 11:17:00 AM(UTC)
Freezer leaking help (Refrigerator & Freezer Repair)
by joec4571 7/26/2010 9:28:02 AM(UTC)
amana bottom freezer leaking (Refrigerator & Freezer Repair)
by joe1934 3/5/2010 1:25:38 PM(UTC)
old freezer leaking air causing ice buildup (Refrigerator & Freezer Repair)
by badtothebone 9/25/2009 12:32:08 PM(UTC)
Freezer leaking out of bottom (Refrigerator & Freezer Repair)
by PeabSS87 8/20/2009 4:27:55 PM(UTC)
