joe1934
#1 Posted : Friday, March 5, 2010 1:25:38 PM(UTC)
joe1934
I found evidence of water under the right rear of my amana (warped the wood floor ). Removed back panel. No water in drip pan and no water in any visible areas. 1/2 in plastic pipe leads to drip pan but ends about even with the edge of the pan. Should I extend the pipe? Is it possible the drip pan is overflowing?
magician59
#2 Posted : Friday, March 5, 2010 1:30:25 PM(UTC)
magician59
Yes. Especially if the damage is in the area of the drip pan.
joe1934
#3 Posted : Friday, March 5, 2010 1:34:56 PM(UTC)
joe1934
damage is in that area...if over flowing is there a solutiton?
magician59
#4 Posted : Friday, March 5, 2010 1:41:18 PM(UTC)
magician59
Drip pan overflow may be a symptom of a defrost problem. Occasionally look into the freezer and see if there is any build-up of a snowy frost. If you se some, you most certainly have a defrost issue.
joe1934
#5 Posted : Saturday, March 6, 2010 7:21:35 AM(UTC)
joe1934
No frost evident Now and don't recall ever seeing any.
magician59
#6 Posted : Saturday, March 6, 2010 12:41:01 PM(UTC)
magician59
Then it's probably just poor placement of the drip pan in reference to the drain tube.
joe1934
#7 Posted : Monday, March 8, 2010 11:38:42 AM(UTC)
joe1934
Thanks for the advice...I pieced a length of tube onto the drain tube to get more over the pan...hope it works.
magician59
#8 Posted : Monday, March 8, 2010 11:44:27 AM(UTC)
magician59
Let us know.
