I cant figure out where the water is coming from. I turned off the water to the fridge and still I'm getting large puddles daily.I turned it off for for days thinking the drain in the freezer was clogged but it started leaking again. :confused:
Originally Posted by: ladyred1101 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I cant figure out where the water is coming from. I turned off the water to the fridge and still I'm getting large puddles daily.I turned it off for for days thinking the drain in the freezer was clogged but it started leaking again. :confused: Got it fixed!!! Took the back off and ran a pipe cleaner with hot soapy water down the drain from inside the freezer compartment and a big clump of yuk popped out into the drain pan! But it hasnt leaked since. Thanks all! Wish I had done this sooner would have saved damage to the floor. Oh well next project.
