Nana Sandy
#1 Posted : 16 years ago
Nana Sandy
The water line on our refrigerator leaks out the bottom. The ice maker works just fine, it's just the water. I'm trying to figure out what part to order.
woodchuckie
#2 Posted : 16 years ago
woodchuckie
Try to pin point the exact location of the leak.
Your drain tube could be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Your drain pan under the fridge could be full because of excess defrost water or a water filter stopped up. (if you have one).
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 9 months ago
Refridgerator keeps running - thermostat bad? (Refrigerator & Freezer Repair)
by PatInPA 11 months ago
Kenmore Elite Refridgerator 795.799773.903 (Refrigerator & Freezer Repair)
by Rick_Titus about a year ago
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest about a year ago
Whirlpool Refridgerator GD5SHAXLQ02 - Freezer too warm (Refrigerator & Freezer Repair)
by Guest 3 years ago
thermostat issues in maytag refridgerator (Refrigerator & Freezer Repair)
by someguy78 3 years ago
Fridgedaire Refridgerator FRS241 (Appliance Parts)
by Dremcatcr 3 years ago
GE gsh25jfxbww refridgerator (Refrigerator & Freezer Repair)
by David Heath 3 years ago
Whirlpool refridgerator repair (Refrigerator & Freezer Repair)
by HectorMartinez 3 years ago
Whirlpool Refridgerator (Refrigerator & Freezer Repair)
by mikecain01 4 years ago
ge refridgerator not working (Refrigerator & Freezer Repair)
by geno630 4 years ago
Freon leak in Viking refridgerator...repairable? what else can i do? (Refrigerator & Freezer Repair)
by viper_gts 5 years ago
GE Refridgerator model PSS25NGNAWW (Refrigerator & Freezer Repair)
by shuskey450 5 years ago
refridgerator section is not cold enough (Refrigerator & Freezer Repair)
by androidx1 5 years ago
Fan Constantly Running on Viking Refridgerator (Refrigerator & Freezer Repair)
by deeni 5 years ago
