Joined: 7/18/2020(UTC) Posts: 0  Location: sevierville TN
Replacement compressor shows only 2 wires to hook up on the new comp which has a combo relay and overload. one terminal on the bottom ( black wire)other terminal to the side (orange wire and I am assuming the black is to the overload and the orange is to the relay. The old comp had a capacitor,overload and a relay,(black wire)went to the overload and the relay had a (orange wire)and a (white wire from the capacitor) which also went to the relay. Question how do I rewire to work, what do I do with the white wire?
