The water line on our refrigerator leaks out the bottom. The ice maker works just fine, it's just the water. I'm trying to figure out what part to order.
Try to pin point the exact location of the leak.
Your drain tube could be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Your drain pan under the fridge could be full because of excess defrost water or a water filter stopped up. (if you have one).
