Nana Sandy
#1 Posted : Monday, April 13, 2009 4:48:05 AM(UTC)
Nana Sandy
The water line on our refrigerator leaks out the bottom. The ice maker works just fine, it's just the water. I'm trying to figure out what part to order.
woodchuckie
#2 Posted : Monday, April 13, 2009 6:09:53 AM(UTC)
woodchuckie
Try to pin point the exact location of the leak.
Your drain tube could be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Your drain pan under the fridge could be full because of excess defrost water or a water filter stopped up. (if you have one).
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 6/10/2024 9:18:21 AM(UTC)
Refridgerator keeps running - thermostat bad? (Refrigerator & Freezer Repair)
by PatInPA 4/17/2024 1:53:30 PM(UTC)
Kenmore Elite Refridgerator 795.799773.903 (Refrigerator & Freezer Repair)
by Rick_Titus 10/7/2023 4:28:57 PM(UTC)
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
Whirlpool Refridgerator GD5SHAXLQ02 - Freezer too warm (Refrigerator & Freezer Repair)
by Guest 3/1/2022 11:17:14 AM(UTC)
thermostat issues in maytag refridgerator (Refrigerator & Freezer Repair)
by someguy78 2/26/2022 7:58:31 AM(UTC)
Fridgedaire Refridgerator FRS241 (Appliance Parts)
by Dremcatcr 1/23/2022 11:15:03 AM(UTC)
GE gsh25jfxbww refridgerator (Refrigerator & Freezer Repair)
by David Heath 11/13/2021 4:10:59 AM(UTC)
Whirlpool refridgerator repair (Refrigerator & Freezer Repair)
by HectorMartinez 10/8/2021 12:22:46 AM(UTC)
Whirlpool Refridgerator (Refrigerator & Freezer Repair)
by mikecain01 10/7/2020 3:37:19 AM(UTC)
ge refridgerator not working (Refrigerator & Freezer Repair)
by geno630 9/10/2020 11:57:49 AM(UTC)
Freon leak in Viking refridgerator...repairable? what else can i do? (Refrigerator & Freezer Repair)
by viper_gts 7/29/2020 7:29:30 AM(UTC)
GE Refridgerator model PSS25NGNAWW (Refrigerator & Freezer Repair)
by shuskey450 7/18/2020 9:24:05 AM(UTC)
refridgerator section is not cold enough (Refrigerator & Freezer Repair)
by androidx1 6/8/2020 9:38:34 AM(UTC)
Fan Constantly Running on Viking Refridgerator (Refrigerator & Freezer Repair)
by deeni 4/7/2020 5:09:06 AM(UTC)
