arrows
#1 Posted : Sunday, November 25, 2007 5:46:07 AM(UTC)
arrows
Dryer starts and runs for awhile then starts making buzzing noise before it stops. After it sits awhile it will restart, but problem will repeat itself a few times before load is done. My guess is either thermostat safety or timer?
jumptrout51
#2 Posted : Sunday, November 25, 2007 6:25:16 AM(UTC)
jumptrout51
Groups: Expert
Check rear drum support for excessive wear. A dragging drum will cause the motor to overheat and shut down.
You may hear a scrapping noise at rear of dryer.
Kenmore dryer stops after few minutes with wet light blinking (Dryer Repair)
by mhren 8/19/2017 6:41:02 AM(UTC)
Whrilpool gas dryer stops in heat cycle (Dryer Repair)
by Percy2459 7/6/2017 1:08:27 PM(UTC)
Dryer stops after 20 minutes (Dryer Repair)
by Mr.Ford 2/23/2017 8:31:29 AM(UTC)
by mgbrinkman 2/13/2017 7:56:55 AM(UTC)
Dryer Stops - But Re- Starts Immediately (Dryer Repair)
by pickmari 2/9/2017 7:57:54 AM(UTC)
Dryer stops mid-cycle (Dryer Repair)
by DIYDave 12/10/2016 5:31:36 PM(UTC)
Dryer stops heating (Dryer Repair)
by NYMountainair 7/18/2016 7:29:27 PM(UTC)
Roper Dryer Stops Mid Cycle (Dryer Repair)
by bradford0113 1/26/2016 6:08:16 AM(UTC)
Dryer stops running after 20 min on heated cycle (Dryer Repair)
by Olaf_sc 11/2/2015 9:05:28 AM(UTC)
Whirlpool GEW9250PW0 dryer stops mid-cycle but timer continues counting down (Dryer Repair)
by Wixman 7/18/2015 1:13:34 PM(UTC)
Old Maytag dryer stops heating after few minutes (Dryer Repair)
by OmaDee 6/23/2015 8:11:24 AM(UTC)
Roper Dryer stops working, then heater runs in all cycles including no heat. (Dryer Repair)
by econobiker 1/7/2015 8:50:40 AM(UTC)
Dryer stops after 5 minutes (Dryer Repair)
by wetlabs 11/14/2014 12:18:52 PM(UTC)
Frigidaire dryer stops (Dryer Repair)
by sham63 10/13/2014 9:08:18 AM(UTC)
Dryer stops after a few minutes on sensor cycle (Dryer Repair)
by wxman 10/5/2014 10:19:26 AM(UTC)
