DIYDave
#1 Posted : 8 years ago
DIYDave
Part way through the drying cycle the sound starts changing. It keeps changing for 30 seconds or so and then stops. If I try to restart it, it hums or buzzes but won't start. Let it cool down and it will restart for a while, the sound changes and it stops again. Is it the motor?
ThatGuy
#2 Posted : 8 years ago
ThatGuy
Groups: Expert
United States
Sounds a lot like the motor bearings seizing up. If you take it apart down to the motor, the motor should spin easily and keep spinning for a few seconds. If it makes noise or stops after a couple of rotations, its probably the bearings, which are non-replaceable.
The motor.
Whirlpool 279827 Dryer Drive Motor - AppliancePartsPros.com
DIYDave
#3 Posted : 8 years ago
DIYDave
Thanks to ThatGuy for the response. That is something I should have thought of myself.
Whirlpool GEW9250PW0 dryer stops mid-cycle but timer continues counting down (Dryer Repair)
by Wixman 10 years ago
duet dryer stops mid-cycle (Dryer Repair)
by Sharpkat 15 years ago
Dryer stops mid-cycle (Dryer Repair)
by ChadwickO 15 years ago
