Mr.Ford
#1 Posted : Thursday, February 23, 2017 8:31:29 AM(UTC)
Mr.Ford
Doesn't matter witch time setting I put my dryer on it shuts off after 20 minutes. Air flow is fine and it does heat up. Can't tell if it's over heating or not.
PNWDrew
#2 Posted : Tuesday, February 28, 2017 7:27:47 PM(UTC)
PNWDrew
It does this on timed and sensor dry cycles? If you set it for 45 minutes timed dry it stops at 20 minutes anyway?
Dryer stops after 20 minutes (Dryer Repair)
by mgbrinkman 2/13/2017 7:56:55 AM(UTC)
Amana Gas Dryer Stops after 20 Minutes. (Dryer Repair)
by Sun1 9/14/2013 6:55:27 PM(UTC)
