mgbrinkman
#1 Posted : Monday, February 13, 2017 7:56:55 AM(UTC)
mgbrinkman
Not sure on age, but thinking this.
Serial: 657189LX
Dryer stops after about 20 minutes, regardless of what you set the setting on.
will order part here!
PNWDrew
#2 Posted : Saturday, February 18, 2017 7:17:08 AM(UTC)
PNWDrew
1)Does it stop as it the load is finished drying or just stop leaving the timer in what would be an on position?
2) When it stops can you restart it immediately? Or does it need to rest 15-20 minutes?
3) If this has a timed dry cycle does it also stop after 20 min, even if timer is set to be longer?
Dryer stops after 20 minutes (Dryer Repair)
by Mr.Ford 2/23/2017 8:31:29 AM(UTC)
Amana Gas Dryer Stops after 20 Minutes. (Dryer Repair)
by Sun1 9/14/2013 6:55:27 PM(UTC)
