Replacement parts for FRG GLER331AS2 | AppliancePartsPros.comHere is a wiring diagram
ftp://ftp.electrolux-na.com/Pr...DF/Webster/134054800.pdfCan you control the temperature in timed dry?
Also does the timer advance in auto cycles?
If yes the odds are high that the problem is the timer.
Timer contacts A (ORG orange) to B (RED) are not closing in auto cycles.
Could be the CONTROL THERMOSTAT but this is the same for both timed and auto cycles.
As Gene stated the only way to tell for sure is with a meter.
Unplug the unit
Put the timer half way in an auto cycle
Open up the console
Remove the A (ORG orange) wire from the timer
Measure for continuity from this timer connection to B (RED) connection.
Should be 0 ohms.
If not re: open (infinite ohms)
Move the timer to mid way timed dry
Measure the above again
If it is now 0 ohms
The timer is shot, for sure.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
