mickayla3
#1 Posted : Tuesday, March 31, 2009 7:37:38 PM(UTC)
mickayla3
The dryer that was working for the past few days has decided to stop heating and we cant figure out why.
Other info:
Electric Dryer model gler331as2
The dryer has been in storage for a while. This is the first time being used in this house. Was working fine this weekend.
What we have tried:
Vacuuming the lint trap, opening the back panel and vacuuming that as well. Was light lint, nothing horrendous. Took off the vent, metal and not kinked, and found a huge clog in the wall. Ran the dryer un-hooked to the vent tube for 10min and still no heat. Flipped the breaker a few times, no heat.
We are at a loss as to what to try now. My fiance is not electrically-minded and we have no electrical tools. Is this an easy fix or do we need to hire someone?
Thanks in Advance!
#2 Posted : Wednesday, April 1, 2009 4:32:31 PM(UTC)
You have to have a simple multimeter to test a few parts. If he knows how to handle a simple tools, this job is not going to be very hard for him. Let us know when he is ready.
mickayla3
#3 Posted : Wednesday, April 1, 2009 7:20:02 PM(UTC)
mickayla3
We tried it on a timed cycle and the dryer heats up, but not on the sensor-dry setting. Is this a simple fix, a sensor to replace?
#4 Posted : Thursday, April 2, 2009 3:55:32 AM(UTC)
Replacement parts for FRG GLER331AS2 | AppliancePartsPros.com
Here is a wiring diagram
ftp://ftp.electrolux-na.com/Pr...DF/Webster/134054800.pdf
Can you control the temperature in timed dry?
Also does the timer advance in auto cycles?
If yes the odds are high that the problem is the timer.
Timer contacts A (ORG orange) to B (RED) are not closing in auto cycles.
Could be the CONTROL THERMOSTAT but this is the same for both timed and auto cycles.
As Gene stated the only way to tell for sure is with a meter.
Unplug the unit
Put the timer half way in an auto cycle
Open up the console
Remove the A (ORG orange) wire from the timer
Measure for continuity from this timer connection to B (RED) connection.
Should be 0 ohms.
If not re: open (infinite ohms)
Move the timer to mid way timed dry
Measure the above again
If it is now 0 ohms
The timer is shot, for sure.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
