Great forum....... I have a whirlpool GD5RHAXNQ01 that decided to flow water out of the ice maker onto the floor. I replaced the inlet valve and filter and I now get nothing from the IM. I removed the ice makers motor head cover and measured 104 volts at the N and L test ports. when I inserted a jumper in the H and T ports with the ice maker connected, the motor did not run.
What should I do next.......does it sound like a bad IM?
Thank you for any help you can provide.
Mike
Install jumper and thyen push the door switch. Most units will not have power with door open.
