water leaks on high water setting it it won't leak on low. has [2] two settings. thanks:confused:
Hi Rayh
How it leaks? Does it over flow?
In order to provide the most accurate advise I need the complete model number of your washer.
Gene. hope i am on right site now. the washer leaks when spin/drain is going on. mod#RAX4232RQ3 ser#CS4511665 thanks
