lou85ta
#1 Posted : Wednesday, January 30, 2008 12:07:49 PM(UTC)
lou85ta
there is on oil or grease like substance coming from underneath the agaitator. Is there a bad seal that needs to be replaced? it is a pretty old washer is it even worth my time.
#2 Posted : Thursday, January 31, 2008 1:49:50 AM(UTC)
Pull agitator and check. If a bad tub seal, it requires a lot of labor and probably not worth fixing.
oil or grease leak? (Washer Repair)
by lou85ta 1/28/2008 3:56:49 PM(UTC)
