redbass115
#1 Posted : Thursday, June 9, 2011 3:21:26 AM(UTC)
redbass115
The dryer appears dead nothing works on the control panel. I did all the diagnostics and felt sure it eas the control board so I replaced it and still nothing happens
Joe / APP Team
#2 Posted : Thursday, June 9, 2011 5:24:29 AM(UTC)
Joe / APP Team
Redbass,
Is this a gas or electric dryer ?
(a model number would be a great help)
If it's an electric(220 VAC) dryer, did you check and make sure you have 220 VAC to the dryer outlet (reset the breaker a couple of times and re check the voltage).
Most of that type and brand dryer have a "thermal fuse" on the blower assembly, that opens and turns the power off to the control, that is a "one shot" fuse and will need to be repalced if it is open, it also indicates that you had a heating problem.
With a model number we can give you more accurate information and get you up and running.
Thanks,
Whirlpool Calypso Dryer - error code 05 (Dryer Repair)
by goffa 2/2/2012 8:41:04 AM(UTC)
whirlpool calypso dryer (Dryer Repair)
by kirtiswilliams53 6/8/2011 4:28:57 PM(UTC)
Kenmore Calypso Dryer (Dryer Repair)
by sunnywene 4/1/2011 6:21:54 PM(UTC)
Kenmore Calypso Dryer (Washer Repair)
by sunnywene 3/31/2011 8:04:35 AM(UTC)
Help on accessing door switch in calypso dryer (Dryer Repair)
by gottado 11/8/2010 3:28:55 PM(UTC)
Fancy Kenmore Calypso Dryer--No Heat (Dryer Repair)
by steve7 8/7/2010 10:45:36 PM(UTC)
Calypso Dryer Contol Panel Problem (Dryer Repair)
by Tony1057 8/3/2009 3:33:38 PM(UTC)
by joeamcneil 11/6/2008 4:47:38 AM(UTC)
