AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Help on accessing door switch in calypso dryer
Any help would be appreciated on this dryer, the famous Calypso. The dryer would not start, after some forum reading as to why she was not starting and probing I discovered that part of the actuator or lever for the door switch had broken off. The switch is good as I depresed it with a plastic pen cap and started the dryer. What I need help on, is the secret to get to the swtich to replace the lever on this model: Whirlpool GEW9868KL0.
Thanks in advance to any help
Did some searching on line and finally figured it out. :rolleyes:
Dryer Repair
