gottado
#1 Posted : Monday, November 8, 2010 3:28:55 PM(UTC)
gottado
Any help would be appreciated on this dryer, the famous Calypso. The dryer would not start, after some forum reading as to why she was not starting and probing I discovered that part of the actuator or lever for the door switch had broken off. The switch is good as I depresed it with a plastic pen cap and started the dryer. What I need help on, is the secret to get to the swtich to replace the lever on this model: Whirlpool GEW9868KL0.
Thanks in advance to any help
gottado
#2 Posted : Tuesday, November 9, 2010 3:15:41 PM(UTC)
gottado
Did some searching on line and finally figured it out. :rolleyes:
