JimLittle
#1 Posted : Friday, February 20, 2009 5:55:04 AM(UTC)
JimLittle
I have an F7 error on the control panel. I already read the tech guide and realize that this is either the control panel or the control module to which it is attached. Both parts are pricey, so I am trying to determine which of the two is bad.
I have tried to unplug the ribbon cable from the control panel to the control module, but then I get an F0 error.
Symptoms: Weird--one day the oven just started beeping when not having been used in weeks. I removed power to the oven (via breaker) and when I restored power the problem did not recur for several hours. Now I have to keep power to the oven off or it ill inevitably beep.
Oddly, I can add power and use the oven for an hour or so before the F7 reappears.
In an effort to try to "unstick" one of the buttons, I pressed each one many times. This did not prevent the F7 from coming back, so I suspect the problem is in the control module and not the panel.
Does anyone here have any ideas for me to avoid having to order both parts?
Thanks,
Jim
#2 Posted : Friday, February 20, 2009 4:33:00 PM(UTC)
Hi Jim,
Based on my experience (I had serviced about 200 GE ovens with the claim like yours) the chance for the control panel to be a culprit is more than 90% because of damaged ribbon. Couple times I had to replace both the control panel and the control board to solve the problem.
- The part number for the control panel is AP2029572
Here are the break down diagrams and the parts list for the GE oven Model JT950SA2SS
JimLittle
#3 Posted : Friday, February 20, 2009 5:30:14 PM(UTC)
JimLittle
Hi Gene,
Thank you so much for your reply.
Not that this is your problem, but I am very disappointed with GE quality. These types of buttons are a very bad idea, I think, especially since they seem to have a very short life span. I would prefer buttons that work by the touch rather than pressure. I have hardly used this oven!
I will do as you say (unless someone else chimes in and says otherwise) and order the control panel. First, however, I will remove the existing panel and see if I can somehow clean or service it, since that is what I do (I'm a tinkerer and I believe most things can be fixed versus replaced).
Thank you very much for your thoughts.
-- Jim
#4 Posted : Friday, February 20, 2009 7:53:45 PM(UTC)
F7 Error (Oven Repair (including Ranges and Cooktops))
by drhdrh 12/4/2014 7:00:36 AM(UTC)
Microwave F7 Error Code (Microwave Repair)
by Pete12 8/2/2012 10:24:59 AM(UTC)
F7 error code (Oven Repair (including Ranges and Cooktops))
by IASTEELERSFAN 12/8/2011 7:33:29 AM(UTC)
GE Range-F7 Error (Oven Repair (including Ranges and Cooktops))
by goran2100 5/20/2011 8:41:27 AM(UTC)
by shirleyss9 2/10/2010 8:21:10 AM(UTC)
F7 Error Code for Ge Profile XL44 (Oven Repair (including Ranges and Cooktops))
by Dougg33 6/25/2009 7:33:59 PM(UTC)
f7 error and light stays on (Oven Repair (including Ranges and Cooktops))
by ttb 6/15/2009 7:21:11 PM(UTC)
F7 Error Code (Oven Repair (including Ranges and Cooktops))
by BERTOLIS 10/2/2008 12:51:22 PM(UTC)
Thermador F7 Error (Oven Repair (including Ranges and Cooktops))
by PSU 7/16/2008 6:51:53 AM(UTC)
Intermittant F7 error, oven light flashes (Oven Repair (including Ranges and Cooktops))
by dshefley 6/30/2008 11:49:52 AM(UTC)
Maytag oven F7 error (Oven Repair (including Ranges and Cooktops))
by ratflinger 4/10/2008 5:33:04 PM(UTC)
