I saw Range Oven Fault codes thread but I did not see any mention of F7 Error. I have GE Electric Range JSP42W5WW which is showing F7 d6 error. It beeps continuosly until I press Clear then it will stop & start beeping after 5 mins. If I press START it stops beeping but it shows F7 d6 error . My oven does not work. I will appreciate your help. Is it Key pad issue or ERC issue?
Thanks.
Goran
Thanks a lot,Gene. I will change Key panel & hopefully it will work out.
Color is White. Goran.
