goran2100
#1 Posted : Friday, May 20, 2011 8:41:27 AM(UTC)
goran2100
I saw Range Oven Fault codes thread but I did not see any mention of F7 Error.
I have GE Electric Range JSP42W5WW which is showing F7 d6 error.
It beeps continuosly until I press Clear then it will stop & start beeping after 5 mins. If I press START it stops beeping but it shows F7 d6 error .
My oven does not work.
I will appreciate your help.
Is it Key pad issue or ERC issue?
Thanks.
Goran
#2 Posted : Friday, May 20, 2011 5:19:46 PM(UTC)
Goran,
Most likely the problem is a bad key panel, but there is a small chance for the control board to be bad as well. GE does not give us any reliable way to test it. I would replace the key panel first. If you need the correct part number, post the color of it.
Here are the breakdown diagrams and Replacement parts for General Electric JSP42WK5WW Electric range | AppliancePartsPros.com
goran2100
#3 Posted : Saturday, May 21, 2011 11:37:16 AM(UTC)
goran2100
Thanks a lot,Gene.
I will change Key panel & hopefully it will work out.
Color is White.
Goran.
#4 Posted : Saturday, May 21, 2011 1:23:35 PM(UTC)
You are welcome Goran.
- The white key panel Part number: AP4415907
