Our GE Profile Spectra XL44 (Model JGBP90MEB6BC) started having "F7" episodes. I followed the manual instructions (let it cool down, if still a problem unplug for 5 minutes, plug back in) to no avail. Then I found some help here suggesting it's either the controller or the keypad. I unplugged the ribbon from the keypad to the controller and plugged the oven back in...No error. From the logic provided me, this means that the keypad may be the problem. I ordered a new keypad for my model (Part #WB57K10048). AppliancePartsPros had it out to me within days. I was all ready to install it, had everything disassembled, when I realized that the ribbon for the new front panel is on the opposite side from the old panel. If I'm looking at the oven from the front when it's assembled, the old ribbon connects to the controller on the left side. The new panel, when installed with the buttons in the proper orientation (not upside down), has the ribbon on the right side. The ribbon is not long enough to go through the slot, over the controller and plug into the other side. HELP! It looks like the panel could have the ribbon come out on either the left or right sides...Do I need to specify this when I order?
What am I missing?!?
I checked with Customer Service and they sent me here. Please help if you can...We need an oven!
Thanks so much for all the help!
Dougg33
I have same problem i guess? F7 E9 flashing when i get it cleared and set oven it will turn off and oven clean will read out then i clear it and code comes up? its a real major problem ! i cleared it unpluged ribbon with power on only thing reading was clock! pluged ribbon in andself clean came on reading? cleared off. Is it key pad or control??? THANKS DAVE>>>
