My GE Profile Performance oven intermittently will flash an F7 message, and the oven light will flash off and on. If I shut off the breaker, leave it for an hour, turn breaker back on it will be fine, sometimes for months, sometimes for hours!!:mad::(
A permanent fix to the F7 error problem was developed by Charlie Popeck, a professional engineer. It involves inserting a piece of paper between two ribbon cables to eliminate the possibility of short circuit between the two cables. The 30 minute procedure is described (including photos) at the web site The Dreaded "F7" Error - FixYa
If that does not work, you will need a new keypanel
