Convection oven CWE9030BCE, gives F7 error. I have replaced the Clock/controller with a new unit & it still gives the same code. I would appreciated some help on troubleshooting this.
The "F7" error code means "...a function pad stuck in the depressed position or the electronic control malfunction". You already replaced the electronic control and now the only failure suspect is the control panel. - The part number for the white control panel is AP373725 Here are the break down diagrams for the Maytag oven Model CWE9030BCEGene.
Yeah, I was afraid that was the answer. Thanks for the tip. I'll get one on order.
