My washer started leaking today. Seems to be on the drain cycle. It leaks form the left side. No apparent leaks on the fill cycle. washer may not be draining completely.
In response to my earlier inquiry, I've discovered a possibility to my own question. It seems that I have a defective pressure switch. The washer does not stop filling once a reasonable water level is reached. I'm trying a smaller load setting now to see what the cut off threshold is.
That will do it, go ahead and replace the switch, you will be much happier for doing that.
Thanks, the part should show up mon. after lengthy observation, i'm convinced this is the culprit.
